2 Air Units with Herelink & 1 Controller Unit - How to Set Up One Air Unit as a Repeater?
Hello everyone,I’m working on a project where I need to connect two Herelink Air Units to a single Herelink controller. My goal is to have one Air Unit mounted on the vehicle and the other functioning as a repeater to extend the range or improve the signal between the Air Unit on the vehicle and the controller.Here’s what I’m trying to achieve:Air Unit 1: Mounted on the vehicle (drone/rover) and connected to the vehicle’s systems.Air Unit 2: Positioned remotely as a repeater to relay the signal between Air Unit 1 and the Herelink controller.Controller: Used to control the vehicle via the relayed signal.Questions:Is it possible to set up the second Air Unit as a repeater within the Herelink system?If yes, what are the steps to configure both Air Units and the controller to work in this setup?Are there any specific firmware versions or settings required to enable this functionality?Has anyone successfully implemented this kind of configuration, and if so, could you share any tips or potential issues to look out for?Any help or guidance would be greatly appreciated!Thanks in advance.
You can’t pair two air units to the same controller
You can’t set one as repeater. Herelinks air units are made to be paired with only one GND unit or another air unit but not both at the same time, in the configuration you are looking for.
