I understand that a 2nd camera cannot steam video simultaneously along with the 1st camera at this current time (I’m praying to the Herelink Gods for that firmware update). Has anyone experimented with running camera1 via herelink and camera2 via Raspberry Pi? My company wants a dual camera feed so trying to brainstorm a workaround to get two simultaneous camera feeds to a ground station that has two monitors.
Do you mean streaming 2nd video via pi through any other mean of communication?
Yep! Kind of imagining hooking up a camera and video transmitter to the Pi purely as a workaround to herelink not being able to simultaneously broading casting 2 cameras. I’m just not familiar with all the tech out there so kind of probing your guys knowledge
In this case you can do this without Herelink. There are many ways to broadcast video from pi to other devices such as wifi/bluetooth/telemetry/etc.
You can google it.
Kindly send the link for such a RASPI telemetry through Herelink… The primary idea is to have a video display from Pi to the Herelink GCS display
You may have a look at this discussion.
Is it possible to talk to RasPi via a VNC viewer installed on the Herelink GCS during mid flight .
I have never tried to do this so I’m not sure if it will work.
Please share the procedure on the forum if you successfully set it up. This sounds a very interesting usage.
But also beware that switching outside from GCS app during the flight is risky.
