About RCIN input
Hello Team,
i am using Orange-cube autopilot, in that i am facing problem with RCIN port which is not taking the input from RC Tx. I checked the connectivity between the controller port(500) and Connector(P304), there is a connectivity, but still controller not taking the inputs.
Shilpa.
What transmitter and receiver?
What carrier board do you have?
Which firmware version are you using?
Hello Team,
  1. FLYSKY FS-i6 X TX, RC Transmitter used.(Its Tested)
  2. ADS-B Carrier Board used ( uAvonix ADS-B IN Receiver on Serial 5).
  3. PX4 V1.15.0
shilpa
Make sure PPM is selected as the receiver output, or i-Bus if your receiver supports it.
Depending what receiver you have the PPM output will be on the Servo1 pins, or the i-Bus output will be on the horizontal “Servo” pins (to the right in this picture)
i-Bus is the term Flysky use for what we commonly call SBUS, and would be the preferred protocol.
Hii all,
I have selected S-BUS configuration and PWM. Still its not working.
Hii all,
Any response on this. i have selected S-BUs only.
Shilpa
Have you got a photo of the receiver and connections all the way to the carrier?
