ADS-B Carrier works with Black cube?
Can the black cube work with the ADS-B carrier?
thanks
The ADSB RX should be on Serial 5, see if you can set the appropriate params and it might work
thanks, I did it that way, but I cant see anything on the map. May be there is not a lot of flight over here…
You will probably need to be outside to hear any.
You may use Flightradar24 to confirm whether there are any planes around.
How do you install FlightRadar24 in Herelink
You can use it on another device, this is my video on the topic
Flightradar24 is a website, but anyway you can install in androids phones
You have to be a little careful with those sort of services as they are slightly time delayed for security
ADSB Exchange is open source-based.
There may be less sources of info than FlightRadar but as far as I know there is no filtering or delays.
Try the “U” filter button (stands for U2) to see what’s going on.
There is also apps for mobile devices.
