ADS-B doesn't work
  • using Cube Orange and ads-B carrier board
  • Firmware: Arducopter 4.0.0
  • MP Version: 1.3.70
  • set parameters
  • ADSB_ENABLE = 1 Enable ADS-B (Disabled as default)
  • SERIAL5_BAUD = 57 Set baud rate
  • SERIAL5_PROTOCOL = 1 Set protocol
  • SR1_ADSB = 2 Set ADSB stream rate to ground station on Telem2
but I can’t see any airplane around me (tested air traffic with flightradar24). With singe uAvionix ADS-B ping it works fine. Any hints what can be wrong? How can I check heartbeat of the internal ADS-B?
Are you outside? Clear line of sight?
Yes, was outside at the same place where the uAvionix Ping works well.
Go for a fly, and compare results. Range should be around 10 miles.
If you are still not receiving any, then RMA it
*** SOLVED ***
Carrier Board had a defect - was changed via RMA.
