Hi altogether,
these are my ADS-B configurations. Unfortunately it works randomly (e.g. shows me other airplane in QGC or MissionPlanner only every now and than) and I have no idea, what exactly may be the cause for that:
Anybody got an idea?
Your radius is set to 0?
Which would mean it ignores all airplanes. You may set it to a reasonable range like 10000m or whatsoever.
My ADSB_RF_CAPABLE is set to 3.
I am on copter 4.0.7.
@Sven - You are absolutely right
- I had this parameter already on another value but did’nt realiize that somehow it changed back to 0. Thanks.
Now it works if the copter is attached via USB-cable to MissionPlanner and here (MP) I see the airplanes around me. In QGC I don’t see anything
May be you want to try SR1_ADSB or SR2_ADSB to 2, depend if you are using telem1 or telem2
Oh. Yes. I never read the document til the end obviously. So Radius 0 should not be the issue.
