Hi all, we are using the air module (v1.1) as our ground station unit instead of the controller module.
Does a firmware variant or configuration option exist for the air module that will allow us to use its ethernet interface to connect directly to a local network in the same way as the WiFi interface does on the ground controller?
The intent is to be able to then run Mission Planner or stream video on other devices on the same network.
