AirUnit antenna cable
I have a defective AirUnit antenna where part oof the plug separated while I was removing it from the AirUnit.
Is it possible to replace only the cable and is the a source for it?
THX, Tobias
It depends on where you are located at. There are distributors selling standalone antenna.
Yes, I know. But the antenna is kind of expensive and I did wonder if there is a possibility to change only the cable. I guess not.
Not sure how is your antenna damaged. Maybe you can try to search for MMCX connectors or antenna with MMCX?
