Hey everyone, very excited about my new Herelink! I am getting it set up and it appears as though the RC pitch is reversed. After doing the joystick calibration (software and hardware) I noticed that pushing forward caused an increase in PWM indicated in Mission Planner. After a while of looking for a way to reverse the channels in the herelink, I ended up just re-doing the calibration and pushing the pitch in the reverse directions. This seems to have solved the issue, as a props off motor test has the correct motors spinning up and down.
Is there something I missed that should have been done to prevent this?
I considered doing this but preferred to just fix it in the transmitter, since that is how I would do it if I were using any other transmitter.
I flew today with no issues at all, it was great. Spring tension on this sticks is quite a bit more than i’m used to and I put in a little expo (which I don’t use on my Taranis), but great otherwise.
I am glad you got this working, but I am having the same problem and nothing I do seems to give me the correct reverse pitch in Arducopter. I have tried everything. No matter what combination of joystick/radio calibration in HereLink, and RC2 settings in Arducopter, I get the pitch stick forward, pwm increase. Maddening. I can’t fly this bird and I’m frustrated. Any help of suggestions would be most appreciated.
