Hello.
I have 4 herelinks. 3 from beta2 batch and one from beta1 batch (updated to lateste firmware as well).
The RollWheel on all beta2 herelinks works fine. However i cannot get it working on one from beta1 batch.
I tried to calibrate it many times, i tried pushing softer, harder, but no luck. What can i do to make it work?
Try to pull the wheel harder. When you feel the spring, it is still far from hard boundary. If you are not pulling hard enough, you will miss a lot of ranges from those tighter area.
