I was able to buy the Beitian BN-880 made by FPVKing (well rated on Amazon), but the seller (FPVKing) says it’s not compatible with the Pixhawk 2.1 Cube. That seems surprising…especially since its listed here: https://ardupilot.org/copter/docs/common-positioning-landing-page.html
Can anyone confirm that it’s not (or is) compatible?
Hm, shoot I ordered this unit but now that it has arrived and I’ve hooked it up, I’m not able to get it working.
I’m able to connect it to GPS2 on the Pixhawk 2.1, and power it up. Based on the status lights the GPS seems to acquire a fix, but in QGroundControl it’s reporting the Pixhawk doesn’t have a fix.
I’m pretty sure I hooked up the TX/RX correctly, but reversed it just to see if that would fix things. It didn’t…
I’m wondering if anyone has any ideas…I’d be very grateful. I took a video of the setup: iCloud Photos - Apple iCloud
Hm, I purchased a UBlox NEO-M8N-0-01 and am getting the same situation - lights on GPS unit indicate a lock, but no lock in QGroundControl. Here’s a video: https://youtu.be/1DXCc3oo-7o
Have you set SERIAL2_PROTOCOL?
Isn’t SERIAL2_PROTOCOL for the TELEM2 port on the Pixhawk 2.1? This unit is plugged into GPS2. Regardless, after your comment, I set it to GPS. SERIAL3_PROTOCOL and SERIAL4_PROTOCOL are also set to GPS.
Other relevant paraemters that are set on the Pixhawk 2.1:
GPS_TYPE = AUTO
GPS_TYPE2 = AUTO
SERIAL4_BAUD = 38400
GPS_AUTO_SWITCH = UseBest
And here’s the wiring diagram that I used to wire up the GPS2 cable:
