I have recently got 2 cubeorange+ and a mini carrier board. I am a px4 developer and am having difficulties in uploading PX4 firmware on cubeorange+ boards.
I have gone through the documentation and it mentions support for both PX4 and Ardupilot.
I have tried flashing firmware using QGC for PX4 and I get the following error message.
I have tried the following in both windows and Linux in QGC, I get same error. ( both cubeorange+ boards ).
With Mission planner I am able to flash Ardupilot and the bootloader ( ChibiOS based ). However I cannot flash PX4 firmware.
In ubuntu I have also tried flashing using
make cubepilot_cubeorange
make cubepilot_cubeorange upload
and also for cubepilot_cubeorange_bootloader and px4_fmu-v3. These upload methods are provided in PX4 documentation.
This ends with either an infinite waiting at
[62/63] uploading px4
Loaded firmware for board id: 140,0 size: 42836 bytes (2.18%), waiting for the bootloader...
or crashes with the following error log
[1071/1072] uploading px4
Loaded firmware for board id: 140,0 size: 1948308 bytes (99.10%), waiting for the bootloader...
Attempting reboot on /dev/serial/by-id/usb-CubePilot_CubeOrange+_40004D000551393136333935-if02 with baudrate=57600...
If the board does not respond, unplug and re-plug the USB connector.
Attempting reboot on /dev/serial/by-id/usb-CubePilot_CubeOrange+_40004D000551393136333935-if00 with baudrate=57600...
Found board id: 1063,0 bootloader version: 5 on /dev/serial/by-id/usb-CubePilot_CubeOrange+-BL_40004D000551393136333935-if00
WARNING: Firmware not suitable for this board (Firmware board_type=1063 board_id=140)
FAILED: platforms/nuttx/CMakeFiles/upload
cd /home/paramd/workspace/px4-changes/PX4-Autopilot/build/cubepilot_cubeorange_default && /usr/bin/python3 /home/paramd/workspace/px4-changes/PX4-Autopilot/Tools/px_uploader.py --port "/dev/serial/by-id/*-CubePilot_CubeOrange*,/dev/serial/by-id/*PX4_BL*,/dev/serial/by-id/*BL_FMU*,/dev/serial/by-id/usb-The_Autopilot*,/dev/serial/by-id/usb-Bitcraze*,/dev/serial/by-id/pci-Bitcraze*,/dev/serial/by-id/usb-Gumstix*,/dev/serial/by-id/usb-Hex_ProfiCNC*,/dev/serial/by-id/usb-UVify*,/dev/serial/by-id/usb-ArduPilot*" /home/paramd/workspace/px4-changes/PX4-Autopilot/build/cubepilot_cubeorange_default/cubepilot_cubeorange_default.px4
ninja: build stopped: subcommand failed.
make: *** [Makefile:235: cubepilot_cubeorange] Error 1
Some forum posts mentions that a PX4 compatible bootloader needs to be flashed.
Has anyone tested PX4 on cubeorange+ (how ?) and flashed px4 compatible bootloader ?
Any help with these issues would be appreciated. Thanks !
