Brd_type issue in Pixhawk cube
I am facing this issue "Check Brd_type: Failed to initialize cube black. Kindly help me with that.
tried various solutions posted on discuss.cubepilot including this link - [STAT_RESET = 0] + Losing parameters + "Check BRD_TYPE" + Critical Service Bulletin on Cube Black
The cube is on the latest firmware. Also attached a screenshot below kindly go through it.
@philip
@Santosh
Please try to reset all params and reload latest firmware. See if the warning still pop out after that.
Already tried still it is popping, tried all possible methods but no luck…
Can you tell what value is inside the parameter BRD_TYPE ?
Does it work on older firmware?
