Working on a carrier board design and wanted some clarity around some pins on the Cube Black.
For instance whats the difference between these two PWM outputs.
Pin 72 IO_CH5_PROT (I/O PWM output channel 5) and Pin 58 FMU_CH5_PROT (FMU PWM output channel 5)
I am guessing one is Aux and one is not.
Also what these pins are for
27 VDD_5V_PERIPH_EN Enable voltage supply for Peripherals
55 VDD_BRICK_VALID Main power valid signal
Is there a document that better describes the pin function.
Also the dimensiaon information for mounting and DF17 placement on the cube black.
Hey Philip
I am using Diptrace. Its what I am most familiar with.
Thank you for the input on the outputs. I suspected that is what it was based on what I have read so far.
Ok so the Cube Black has a method of controlling power to peripheral devices…Interesting. I wasn’t looking to have the cube control any external device…but interesting that it can.
I think that reference design might be worth having a look at.
Thanks man.
Oh and registration yes I saw that. I am a long way from that at this point…more dreaming less designing…lol
I do have the ability to import Eagle boards so perhaps I should reach out to Jeff @apache405
