Hi, I’ve been working on a custom-built ground station that connects one Herelink air unit to another, following the instructions from[[this guide]((https://docs.cubepilot.org/user-guides/herelink/herelink-user-guides/herelink-1.0-airunit-to-airunit-instruction)]) , and it’s working well.
My next task is to connect multiple drones to a single GCS. To achieve this, I need to change the IP address of the Herelink air unit, as I am using it as a ground unit connected to a laptop via Ethernet.
Is it possible to change ip adress of herelink airunit?
If its possible, how would I go about changing the IP address of the Herelink air unit in this setup?
You might be only availble to get the ip by your existing hotspot previous discuss here
Hello, Yashika!
Just wanted to confirm did you find the solution for this problem for connecting multiple airunits to a single GCS or find the solution to change herelink IP address?
Any help in this matter will be highly appreciated.
Regards
Also mentioning the experts here
@philip @Michael_Oborne
