Hi all
Channel 3 stick control revered after updating and stick calibration is not working properly,
@Jeff_jack can you share more details, which firmware are you using? Parameters and video showing the issue will be helpful.
here i attached video
herelink video.zip (3.9 MB)
In this channel 3 is reversed and All the parameters are good but it shows error and check this photo pls below
