iamczar
(iamczar)
8 August 2019 22:28
1
I powered up my cude black for the first time and followed the instruction on the service bulletin
Upon restart I get a Check BRD_TYPE: Failed to init CubeBlack - Sensor
I don’t have a log either.
Mission planner times out when I try to download DataFlash log via mavlink
Has anyone else had this issue? or how any clue on how to resolve it?
Contact your reseller for an RMA
emendes
(Eduardo Mendes)
13 April 2020 20:22
3
I am having the same problem, but the drone was working until a few days ago. What may be the problem?
The leds bellow keep blinking red and it shows the messages:
13-04-2020 14:51:57 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:55 : Initialising APM
13-04-2020 14:51:54 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:51 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:50 : Initialising APM
13-04-2020 14:51:48 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:45 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:45 : Initialising APM
13-04-2020 14:51:42 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:40 : Initialising APM
13-04-2020 14:51:39 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:36 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:35 : Initialising APM
13-04-2020 14:51:33 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:30 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:30 : Initialising APM
13-04-2020 14:51:27 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:25 : Initialising APM
13-04-2020 14:51:24 : Check BRD_TYPE: Failed to init CubeBlack - sensor
13-04-2020 14:51:24 : Frame: UNKNOWN
13-04-2020 14:51:24 : RCOut: PWM:1-12
13-04-2020 14:51:24 : CubeBlack 0048001E 33365110 36313734
13-04-2020 14:51:24 : ChibiOS: d4fce84e
13-04-2020 14:51:24 : ArduCopter V4.0.3 (ffd08628)
MadRC
(Ian )
13 April 2020 21:38
4
emendes:
TYPE
What is your BRD_TYPE set at in prams ?
Exactly the same problem… for me the answer was “If it’s crashed, it could have damaged the internal assembly.” But after a crash that happened perhaps for this Cube faulty all worked before installing the 4.0.3
MadRC
(Ian )
14 April 2020 11:17
6
Again what is your Pram above set too.
emendes
(Eduardo Mendes)
14 April 2020 13:31
7
This is the param:
BRD_TYPE = 3
So if you don’t have the correct parameters loaded from the service bulletin.
Please follow the instructions
emendes
(Eduardo Mendes)
15 April 2020 12:00
9
Which bulletin and instructions?
I see these:
BRD_TYPE == 3
EK2_IMU_MASK == 7
(or EK3_IMU_MASK == 7 if using EKF3)
INS_USE == 1
INS_USE2 == 1
INS_USE3 == 1
