Dorian
(Dorian)
12 January 2020 11:57
1
My wifi network is 2.4Ghz. Rather than switching my whole network to 5Ghz, is it possible to use an RJ45 USB interface with the Herelink?
I wish I could:
download maps for QGC
share video stream to PC
to connect Herelink to Mission Planner on my PC
I tried, but it doesn’t work.
Is there a solution ?
yes its possible but not for your use case
Hi all,
I’m trying to get ethernet pasthrough working. I’m running on the Beta Channel, SRU01200616 on the ground unit and the corresponding version on the air side.
I understand a ethernet adapter with a R8152/8153 chip is required, I have have a ANKER A7610011 and a Cable Matters 202023-BLK for testing. Both use the correct chip according to the Amazon comments, although its very hard to get the information directly from the manufactures.
On the ground side I have a generic OTG adapter, and…
jonesv
(Jonas)
6 February 2023 10:22
3
May I ask why it is not possible for this use-case? I have a similar issue where the adapter is recognized (eth0 is created), but it never gets an IP (I connect it to my router). I would like to understand what I am doing wrong / why my use-case is not supported
