I’ve got one laptop (not very reliable!) that connects UDP no problem. The other laptop (the one I want to use) won’t. I will connect UDPCI though. Is there any difference? It’s just the Herelink documentation specifies to up UDP. I have no idea what the difference is either.
Are they under the same network?
Either would be connected to the Herelink controller’s wifi.
I have just tried on my machines. They works perfectly.
Both of them connects as mentioned in docs.cubepilot
https://docs.cubepilot.org/user-guides/herelink/herelink-user-guides/connect-to-mission-planner#you-are-now-connected-to-the-herelink-hotspot-wifi.
No special tricks required.
