In Solex you can program the wheel to say Aux 1. Then setup D button to Change that to Aux 2 on a short press and a long press to reset back to Aux one.
So if you put pitch on Aux 1 and Zoom on Aux 2 you can do both via the wheel.
The shutter can be programmed for long and short press in the Herelink settings and you can program it to to do both shutter and record but you do need a second button to reset it. My advice on this is to set shutter to the top corner button and then use say C button to start and stop record.
I am also working on a Lua script to allow the camera button to short press take pic and long press record with the Seagull camera controller. The script is done and working but I’m just trying to work out something on Lua with the current stable releases as not everything has the same bindings.
Hello @MadRC , i suppose the proposed setup was available only before the stable release?
i can see that on AAU01210729 you can no longer choose Sbus out on the wheel and also on solex i cant see to find a way to make your setup work, since it allows the wheel up to ch16 and sbus starts from 17. Am i doing something wrong? It seems also that the docs are also outdated and dont follow along with the latest fw changes
