I have seen that in the las release, It is possible (In Solex) to use the buttons to map the wheel to different channels. That’s great because I can use the buttons to assign the wheel to different channels and add a pwm range. However, I am scared that If I wan to tilt the camera down, as soon as I will release the wheel from my finger, the camera will tilt up again. Is there any way to use the wheel to tilt the gimbal but it stays and does not come back when the wheel is released.
That was discussed time ago here, I was one of the ones suggesting that this feature would be cool. I wonder if in this release that feature was added or if it would be in the future. Otherwise it would be impossible to control gimbals from Herelink.
Same need here. However, It would be better if it was handled directly on Ardupilot side as a rate mode gimbal control. ( equivalent as angle mode from alexmos )
I’ve added a thread there few days ago about this.
Is there any way to know if the Herelink Team is thinking about adding this feature? With that Herelink would be 100% complete. Otherwise, anyone who would need to operate a Gimbal, and I think It would be plenty of people, they will have to stay away and change to other controller. I would not like that at all since I have a big investment in several Herelinks.
Could we open a ticket or communicate with the Herelink team to see if they could help us with that>
Well I think that even with the gimbal controller, In the way HereLink works now, you can tilt up or down the camera with the wheel, but as soon as you release it, the signal in the chanel would come back to 1500 and the camera would come back to the original position.
We’ve been able to pan with the wheel and pitch with A and B but it’s a nasty hack. @philip sorry to tag you here, but can you update us on how to best control a 2 axis gimbal? If it’s not possible, is there something in the works?
Hello, What I did, is adding a small microcontroller (micro arduino style) so I can make the mixes that I need. The arduino is located between the Auxliar output of the Cube and the servos that move the gimbal.
There is a solution for gimbal control via the Herelink. Have a look at the HERELINK & PIXHAWK IMPLEMENTATION from airpixel.cz. They control the gimbal from an Android device via the Herelink.
It looks like it’s the way to go.
Which gimbals will be supported? I have a Movi M5 that I would love to use with herelink, but I am not sure it’s supported.
Also, does anyone have any gimbal suggestions for a Sony A7 series camera? I would like to sell the Movi, and get something that works better with the cube.
Nowadays, many and many camera gimbal are in the markets. Not only rgb camera, but also thermal, spotlights that can be control with pwm. As i can see, herelink is limited to only one button wheel, where as we need minimum 2 of button wheel, to control pitch and yaw of the camera. To add on additional button is a no option and the way is only to update the firmware.
I guess the way to go is, the team provide us with below type of operation:
Fly the drone using the herelink controller as usual.
After the drone loiter on a point, press hard button A, the controller will switch to gimbal and camera control. So we can use the joystick to control the movement of the gimbal. Button B C D can be use to use zoom in,out function, focus, record. When finished, press hard button A to return to drone control.
A flysky i6, usd30 price, could do better with its 2 knob compare to usd699 herelink. Please highlight this to the team.
You could use a second HereLink unit now to control the gimbal. Then you have a 1,600 $ fix.
Otherwise I would try to work with LUA scripting on Arducopter to implement the functions you describe.
If you do it via LUA you must change to break flight mode at the point and then redirect the joystick and button inputs to servo outputs. I guess that should be possible if you’re flight controller is fast enough.
I would set A to loiter and B to break, if you are in break mode the left joystick is used to control the gimbal (if you have a 2-axis gimbal you could use the script to turn the copter) and the right to zoom in and out. The cam button can be used to record and e.g. d for focusing. In the end not to complicated I guess.
It would be great if @Michael_Oborne could develop a simple plugin feature where one could change the channel values by using sliders or buttons in QGC.
Finally there is an update (august 2021). It looks like Dual Ops can be use now. But there is no manual about this dual ops. Any manual or document for me to go through? Before i buy second herelink? (I hope the 2 nd herelink joystick can be used to control the gimbal camera as i arrised the issue above)
