i have here3 and here flow both working perfectly with CAN bus enabled.
but i tried to use the i2c port with VL53L1X Lidar sensor and beneweke tf luna i2c sensor separately, but they won’t work. i tested them using a Arduino and sensor modules working fine.
without i2c bus i cannot use any kind of i2c sensors for my project. is there any workaround for this?
i powered them separately. as i tried 4.1 dev . vl53lx1 sensor started to working with i2c. but still no response for benweke i2c sensor.
I’m starting to think, the required library/coding is not within the cube to work properly in the first place. even though in the documentation it says it can use.
yes, its because cube is programmed only for serial mode with those sensors.
but these modules have multiple interface options, which i was trying to get to use the i2c mode of the tf-luna module.
it would be nice, if we get i2c support for tf luna module as well. i know its a long shot.
In this case I doubt if the I2C driver is even exist for this sensor, as the wiki states its serial setup only. You may need to raise a topic on ardupilot forum.
