Cube Black + not compatible with Px4?
Hello to everyone,
i’m trying to flash the Cube Black + with Px4 (using QGroundControl) but i have always an error, even trying to update the bootloader.
The error says that the board id (1003) is not related to any Px4 version.
I’ve read that the cube black + is compatible with the firmware that was compatible with the Black 2.1, but i’m not able to use the Black+ with any Px4 release.
How can i solve this problem?
Cube Black + is not compatible with PX4 firmware,you can try APM firmware.
APM is compatible with all Cube.
Thank you for your answer.
I thought it was compatible because it’s stated that is the transition board between cube black and cube orange, both of which are compatible with PX4.
