OK. I have tried several different versions of MissionPlanner to try and get my Cube ID module to work, but I can’t. I just downloaded the new new copter version, 4.3.7, and now I don’t even see the drone id tab in the Data section anymore. I have tried to follow, as a normal user, the instructions from the Cube ID manufacturer, but their instructions are a bit vague, and jump around from OEM to normal user. Has anyone had any luck with this yet? September is quickly coming and this is the most cost efficient option.
I had to build a custom version of firmware at custom.ardupilot.org to get the DID parameters to show up. That part was pretty easy, I did Add Build (upper right) and selected my vehicle/version/board and made sure to check OpenDroneID in the “Ident” group. Build only took a few minutes to make, and I could download and load via the Load Custom Firmware.
The “Drone ID” tab in the DATA section can be turned on by right clicking the labs, customize, and turn on “tabDroneID”.
