can i use Micro Power Module (PM06 v2) from holybro to power the mini carrier board?
https://shop.holybro.com/micro-power-module-pm06-v2_p1036.html
Why?
They claim 120A continuously at 42v!
That’s 5KW through that tiny resistive load?
That is flat out lying!
The mini brick that comes with the cube would likely last longer without catching fire than that bit of junk…
But I’m biased…
the only reason i am asking for bcz of the size it has PDB for motors also analog and the current sensor is there some similar in the market. my application doesn’t require high load mostly around 40-50amp at max
It’s worth investing on Mauch power modules.
Accurate current reading, reliable power supply for Cube.
