Cube Mounting Screw Redesign Request
Whatever is being used inside the cubes needs some design work. On all of the cubes I’ve used, the mounting screws get to a point where they will not thread completely without the risk of damage. I spent over an hour fiddling with this new Cube+ to no avail. For future versions, please change whatever is inside. Time lost for RMA is expensive with no guarantee the replacement won’t have the same issue.
I have the exact same problem…
I too had similar problems on mini carrier board while mounting cube orange…the screw strength is not enough and easily bend from its original position.
