Hi All,
I have a cube that has gotten picky. It will not show up in device manager/mission planner. I’ve looked on ardupilot and have seen the same problem come up bt no one has found a fix it seems like.
I have been using USB cable direct into the cube itself and not through the supplied USB adapter/connector.
uninstalled mission planner and reinstalled
tried different USB cables
formatted micro SD card
tried different SD card
I know it’s the cube and not the computer. I have tried many other cubes and they are detected and connect fine.
Can’t even install a different firmware since there’s no COM to select.
I’ve run out of ideas. Has anyone had the same problem and been able to find a solution?
Thanks for the help!
