Cube orange and raspberry pi
Hello everyone
I am using a cube orange plus and a raspberry pi 5 ( raspion os ) as a companion computer. I want to connect the rpi5 to the cube via telem 2 but the cube never connects via that. I tried using a USB cable and everything works fine and I can even run python scripts on it . I used /dev/ttyACM0 for that. I would like to eliminate the usb cable if possible and use the telem 2 port to do the same things.
Please help
