Need some advice. There is a lot of conflicting info raising confusion. I have a Cube Orange. I will use 4 APD ESCs (200A F3). They support DShot, and I want to use the telemetry features. With the Cube Orange this seems to mandate Aux 1-4 as my inputs. I am assuming you only use signal and ground from the ESC to the Rail. Right? No other connections for the full telemetry functionality from APD’s ESC? Is the APD a BLHeli? I can’t seem to find this answer. This would dictate which firmware I flash the Cube Orange with right? I don’t want this to get screwed up and end up an unstable mess again. Please advise.
Also, Do I need to send VCC to the AUX rail to aid in supplying power for the Opto-isolator circuits? I know there was concern the Cubes need their power to be supplemented to strengthen for system noise immunity.
