Cube Orange+ connecting multiple Analog signal to ADC
Hello everyone,
I am using a Cube Orange+ Flight Controller with an ADS-B IN Carrier Board, and I need to connect two analog sensors to the flight controller. However, I suspect that the carrier board might limit my options for utilizing the full potential of the Cube Orange+ hardware.
  1. Are there any available analog input pins on the Cube Orange+ with this carrier board?
  2. Can I access additional ADC inputs on the STM32 inside the Cube Orange+?
  3. Is there a way to modify or work around the carrier board’s limitations to utilize the full capabilities of the flight controller?
Any insights, suggestions, or alternative approaches would be greatly appreciated. Thank you!
Hi there, did you figure this out? We are in the exact same position and are struggling to find resources for this.
