Cube Orange Micro USB Replacement
Hi everyone, This is my first time posting so thanks for letting me into the community!
I have a Cube Orange FC that has been performing very well. Unfortunately, during some flights yesterday, I managed to break the USB port cleanly off while downloading some logs.
I was hoping to re-solder the USB port back on, but since removing the cube from the carrier board, I’ve been trying to come up with a proper method to separate the orange enclosure so I can get access to the USB pad. So I was wondering if anyone here has had any experience doing this, and if so what the best method is (or if its even recommended!).
Any feedback is appreciated, and thanks!
Following.
I also need to repair a damaged one but I am afraid of opening it.
the carrier board also has a usb header, so with the correct cable you can use the carrier board instead?
