my setup consists of a cube orange (Pixhawk 2.1), which is connected to a X8R (SBUS <-> RCIN).
The X8R is paired with a FrSky Taranis, which is working so far. This has been confirmed on a Pixhawk 4 as well as directly checking the signals on the SBUS.
However, when I want to calibrate my radio (QGC/Mission Planner) it seems like nothing arrives on the cube. I tested with PX4 as well as Ardupilot, with similar result.
I am wondering if this is a hardware problem on the cube or am I missing something on the setup?
Any help is greatly appreciated.
Are you using a standard carrier? Are you sure you are inputting the cables in the right place? You should input in the “PPM” labeled input, be careful that the “SBUSo” labeled header is in fact a SBUS output, it could confuse some people.
I am using the ADS-B Carrier Board and the receiver is connected to the RCIN header of the board, which should be correct according to the documentation.
The SBUSo is not connected.
I am connected to the SBUS port on the X8R, as far as I am aware no further configuration is required.
I also tested the same setup (X8R+Taranis) on a Pixhawk 4 via SBUS where it works fine.
