Cube Orange SD card Capacity
Hello friends ,
What is the Maximum micro SD card size supported for Orange cube and Black cube?
What class SD card is recommended?
Hi @Jaikrishnan1995,
The answer is within the PX4 User Guide:
https://docs.px4.io/master/en/getting_started/px4_basic_concepts.html#sd-cards-removable-memory
Regards,
@Retro-meb, having the question answered here directly would be more helpful than linking to the competitions documentation and having the reader learn that the maximum supported size for the Pixhawk boards is 32GB. FWIW, they also highly recommend the SanDisk Extreme U3.
Unfortunately it seems that the Cube user manual at the time of writing does not mention the supported card sizes (it only states class 4 or higher as far as I can tell), and @Retro-meb 's assumption that they both are limited to the same cards is probably right, but I think we can do a little better.
@philip who do we ask to update the documentation so that we can be more sure about buying the correct SD cards?
the maximum SD card size is 1TB at this point… we dont mention a limit, as our hardware has no limit other than what is available… when we get our hands on a 2TB cad, we will test to ensure that works as well
