Cube Orange TTL GPS not detected via MAX3232 — need help
Hi all,
I am trying to connect an external TTL GPS module to a Cube Orange using a MAX3232 level converter. The MAX3232 is powered by an external 3.3V regulator and GND is common with the Cube.
Connections are:
  • TX of GPS module → RX of Cube GPS1
  • RX of GPS module ← TX Cube GPS1 (not connected for testing)
Cube parameters in Mission Planner are:
SERIAL3_PROTOCOL = 5
SERIAL3_BAUD = 9600
GPS_TYPE = 5
GPS_AUTO_CONFIG = 1
GPS_RATE_MS = 200
The problem:
  • Cube does not detect the GPS. Mission Planner shows No GPS or EKF3 waiting for GPS config data.
  • I can send NMEA sentences from PuTTY, but the screen stays black (normal, Cube only reads the signal).
  • I have tried sending repeated NMEA sentences including GGA and GPRMC, but Cube still does not detect the GPS.
MAX3232 status:
  • Powered with 3.3V external
  • GND is common with Cube
  • Connections verified multiple times
I am not sure if the Cube is receiving the TTL signal correctly, or if there is a firmware / protocol issue.
I have checked:
  • Baud rate matches SERIAL3_BAUD
  • SERIAL3_PROTOCOL = 5, GPS_TYPE = 5
  • GND common, TX module → RX Cube
  • Sent repeated GGA + RMC sentences
I am looking for advice on:
  1. How to confirm Cube is receiving the TTL signal correctly
  2. Any firmware or parameter settings I might be missing
  3. Whether there are known issues with Cube Orange + MAX3232 TTL GPS
Thanks in advance!
