What would be the best order from the bottom of the cube?
What I’m curious about is that there’s a cube that says Fixhawk 2. I want to know if this is a high or low version.
Fixhawk 2 or Pixhawk 2 ?
The original Cube Black was labelled Pixhawk 2 and marketed a pixhawk 2.1.
This was then later changed to Cube Black.
The actual cube is the same just a naming change when everything moved to Cubepilot.
Then after that we had the Cube Orange l, Yellow and purple ect.
There has never been a Fixhawk, you something is labelled that it’s not an official cube.
