Cube Red PWM out
I am having trouble with the PWM outputs on a Red Cube (I have tried a couple of them at this stage, with the same result) I have installed both ArduPlane and ArcduCopter and the only seem to get PWM signal (on an oscilloscope & tested with a servo) on AUX ports 1-6. These correspond to servo outputs 1-6 within the parameters, which in my experience doesn’t make sense. Usually servo outputs 1-8 are the main outputs and then 9-14 are the aux channels. Any information or link to documentation would be greatly appreciated.
Kind Regards,
Perry
