Various Cubes refuse to connect to Mission Planner on an Intel MacBook Pro 13 2020 running Parallels and either Windows 10 or Windows 11. If I setup Bootcamp on the computer then it connects first time every time so I know its not the Cube or the cables. When I try and connect using my Windows on Parallels then all I get is a Heartbeat Packets Not Received message even though the Cube is correctly showing within Device Manager. I have turned the firewall off but still the same. Any ideas at all? My suspicion is a driver incompatibility with Parallels???
Hi Angus, did you get this sorted, I am having an identical problem with Parallels and Windows 11 though I haven’t tried book camp.
Thanks if you can help.
Peter
Well, I have narrowed it down to being a specific problem with Parallels. I had a long support session with them but no answers from them. What does work is if you use Parallels v15. Hopefully they will fix this in updates but who knows.
