Anybody has experience on the average life (in hours of operations) of the Cube Autopilot?
Lifetime of any product depends on the way and the environment the Cube is used. It would be very hard to obtain statistics on that
Hi Julien, tnx a lot for your answer. I fully agree with you but, due to the high number of cube autopilot delivered, an average indication “could be possible”. Usually these info are calculated under some specific standard like Mil HDBK 217 "reliability prediction of electronic equipments"and are defined as MTBF in number of hours for ground benigne, for example. If these number is unknow, for using the autopilot in a production system we have to give an estimation on the maintenance manual of what it could be the life. If you have any other info it could help, as average, estimated or similar.
