We had a Cube Blue ship without screws. What size and type are used for Cube Blue/Black/Yellow/Green? Standard carrier board if that matters.
M1.6
12mm is a good length
Non magnetic stainless.
Are the screws to mount the standard carrier board to a platform M2.5? If you were to mount the mini carrier board would getting a bit longer M1.6 work to hard mount to frame or would you not mount the mini like that. Trying to get away from using double sticky tape and solid mount everything unless I have vibe issues.
Yes, and yes
Hello, the Cube mounting screws I just pulled out are 20mm long. Note that the information on this page Calls out M1.6 * 8, which is much shorter than what is shipped with the unit
M1.6 x 8mm is minimum length to mount to a 1.6mm pcb.
