I have an Orange Cube with the ADSB carrier board.
The available User Manual - V1.0 - does not address all the connectors labeled on the carrier board.
Is there a document that explains how each connector on the ADSB carrier board is addressed?
For example, there is a connector “ADC.” I can’t find a reference to that anywhere.
There is one connector labeled “I2C” - but it’s labeled “I2C-2”. Is there an “I2C-1?”
The board has GPS-1 and GPS-2 and CAN-1 and CAN-2. It seems there couldn’t be enough serial ports on the CUBE to address all of:
Telem-1, Telem-2, GPS-1, GPS-2, I2C-2. Then there is the USB, ADC and the serial port used for the ADSB receiver.
It would be helpful to have good documentation for this. Thank you.
