I am using the CubeID remote ID product (Serial + CAN). In my setup I have ardupilot firmware on my autopilot with DID_CANDRIVER and DID_ENABLE. I have the can port set to Dronecan and still I am unable to communicate with the device (Is not detected in DroneCAN tab, or DroneID tab).
However, with the same device, using the DID_MAVPORT and DID_ENABLE configuration for the ardupilot, it would work seamlessly through the serial port.
I would absolutely need to use it through CAN.
Thank you for your help
