Dear Community,
Thanks in advance for the community support and feedback on my project.
I am building a drone boat using the electronic hardware listed below and need help connecting the systems together. I’ve started down the rabbit hole on how to use splitters, hubs, and various cables to connect the discrete components but figured this community might help shorten my learning curve.
In summary, I’m looking for help selecting the correct cables and components that would enable the ESC, Cube, and Servos to all be compatible.
Components:
- Orange Cube
- ESC [VESC 75V 300A] (VESC 75V 300A Black Anodised Non Conductive CNC housing)
- Motor Maytech Fully Waterproof Brushless Motor
- BEC MAUCH 021 PL 4-14S HYB BEC
- Battery EV West Battery
- Servo ZOSKAY Coreless Digital Servo
Areas I Need Help With:
- Cables and Connectors: Recommendations for cables and connectors that will ensure compatibility between the ESC, Cube, Servos, and other components.
- Splitters and Hubs: Advice on any necessary splitters or hubs to manage connections.
- General Integration: Any tips or insights on integrating these components seamlessly.
I appreciate any guidance, resources, or advice you can provide to help me successfully connect these components for my drone boat project.
Thank you very much for your support!
