I don’t really understand why I get this error when running a python script in my raspberry pi.
I have connected R-PI’s uart (rx and tx) pins to the Telem 2 port of the cube. I did the same thing when I was using a PixHawk. I have already ran multiple python scripts when I was integrating PixHawk and raspberry pi and all of them worked.
Now that I am using Cube Orange, I get this error.
I tried running maxproxy.py --master=/dev/ttyAMA0 and I can see that there is a connection in the terminal. I can read the vehicle type, the modes, the arm, etc.
However, when I run a python script, this kind of error shows up.
ERROR:dronekit:Exception in message handler for HEARTBEAT
Traceback (most recent call last):
File "C:\Users\munsterlander\AppData\Local\Programs\Python\Python36-32\lib\site-packages\dronekit\__init__.py", line 1531, in notify_message_listeners
fn(self, name, msg)
File "C:\Users\munsterlander\AppData\Local\Programs\Python\Python36-32\lib\site-packages\dronekit\__init__.py", line 1223, in listener
raise APIException("mode (%s, %s) not available on mavlink definition" % (m.custom_mode, m.base_mode))
dronekit.APIException: mode (0, 0) not available on mavlink definition
fn(self, name, msg)
dronekit.APIException: mode (33554837, 0) not available on mavlink definition
Additional info:
Telem 1 is connected to my HereLink’s UART
Telem 2 is connected to my R-Pi’s RX and TX
Serial5_protocol is -1, serial 2 is 2 and serial2_baud is 921600
I tried connecting to the cube orange using through the r-pi’s usb port and it still shows the same error.
I have also read many issues similar to this one because of the Cube Orange and none worked so far. How do we fix this one?
not really fixed but seems like the connection between ug the rpi and the cube is still there even with these warnings. i can even send commands to the cube. the debugging part is just a hassle because these messages keep on appearing
