Trying to wire up the EDU450 carrier board with the Airunit 1.1. The documentation says, " Please connect receiver to PPM(as picture showed),other 2 “SBUS” s are Sbus out
What does this mean? It came with a cable that plugs into the Airunit’s Sbus port and breaks out into two connectors that can connect to the header area in the image routed by the black/yellow wires.
Does connector go on the Sbus header and the other on PPM header?
