I was recently re-calibrating 2 of my drones running on APM2.8, Pixhawk2.4.8 and the EKF status for both of them is showing red (velocity_horiz off and pos_horiz_abs off) this wasn’t the case just a few days back when I flew them perfectly.
I also connected cube orange and saw the same errors.
I’ve calibrated the boards countless times in different locations incase it was a gps issue, but i see those same errors. Moreover the pixhawk is a bit twitchy in stabilize mode and in position hold mode it flips to the back-right (roll right, pitch back).
Firmware version? Logs?
firmware legacy arducopter 4.0.7quad on all the boards, this is the last log of pixhawk 2.4.8 -
https://drive.google.com/file/d/1ze_T78py9eOFtM4DhA-1Osm04aH5mXl1/view?usp=sharing
There is no way you had 4.07 on the APM
Show me the cube log.
APM2.8 is no longer supported.
Please forget the APM, it cannot run firmware that is beyond 3.2.
