Hi everyone,
I am having some issues after calibration of new Normal ESC , during motor Test 7% throttle can only spin motor 1, before motor 2,3,4 can spin I have to raise throttle to 14% . When throttle is raise to 14% all mot spins but Motor1 is much faster than 2,3,4 .
I have changed the brushless motor same thing happened, I switched motor1 ESC for motor4 it start spin at 7% throttle.
Servo Max , Min, trim are all Normal
I think it would be risk building the drone like that when motor1 is faster and start spinning at 7% throttle while others can’t
If you have encountered similar problem and have the solution pls leave a comment
