Hello
Have a few cameras that use ethernet connection but when i connecting them to airunit the video is not available on ground unit. Strange thing that is if i connect camera to air unit using switch or router RTSP video stream becomes available. Any ideas why it works like this? Camera name is Topotek TSHD10T3 but have this issue with few others. Maybe i can configure something through ADB to make it work?
when video is not available you can adb shell to the Airunit and ping the IP of the camera.
The camera is pinging only if connected to air unit through ethernet switch.
