I got this link from Pedals2Paddles post on forum Aug 30 (3/17)
Started to flash OK got about half way then laptop went to ‘bluescreen’
After re-power and on re-trying goes to ‘blue screen’ when USB cable plugged in to CUBE
images attached
Help please, what am I doing wrong, I only got it today !!
Windows 7 is no longer supported by Microsoft, it’s very hard to do any form of troubleshooting on it.
Please update to Windows 10, or switch to Linux.
Hi @philip
Thanks for quick reply
Hmmm. I’d prefer not to, I have other engineering/diagnostic tools which are untested on WIN10.
I’m using the the driver set that Michael Oborne said were now good for WIN7
Tried on another WIN7 machine, bluescreen as soon, well 3-4 seconds, as I plugged in
Tried to flash in Q-GCS with a view to then setting it up in MP.
Uninstalled previous old version, then installed latest,
It reported that it could not find the CUBE-ORANGE BL driver. does BL refer to Bootloader ??
Last night it started flashing, with MP (see OP) but fell over about half way through,
Could this be a hardware issue?
Do you want it back for checking out?
@Hampus_Berggren
Yep, if it turns out I’m going to have to run WIN10 then I’ll dual boot my hard drive
I’ve got a 500GB SSD at moment, maybe an excuse to upgrade to 1TB
@philip
Well… WIN10 flashed the firmware OK
Would not connect to MP at first, ran beta updates and got version 1.3.68.1 and then had ‘driver clean’ which on it’s second run gave me two COM ports and was then able to AUTO connect.
The SB2 parameters where checked, only one needed changing.
However in the ADS-B param settings the following did not exist. I searched in ‘Full Parameter List’
AVD_W_ACTION
AVD_F_ACTION
AVD_F_RCVRY
So, I appear to be up and running.
Did not have good experiences with MP a few years ago, was happy to try it again but recent days have not impressed me. I really hope things get better
Thanks @philip for your help on this forum over the past few days
What do you think I should do about the missing ADS-B parameters
@MadRC
Thanks for this I’ll try it tonight…
Although I now have my laptop dual-boot WIN7 and WIN10 however that was a good thing to do anyway even if not now essential to use CUBE
Cheers
Steve
