I am bringing back my old 3dr X8 to carry a new 3D laser scanner I purchased. I want to give it an overhaul from its 2015 equipment. Here is my new lineup and wanted to get your opinions.
Green Cube
Pixhawk 2.1
Here+ RTK
Livox Laser
Raspberry Pi
DJI Occusync + Goggles
Operating on Open Solo with Solex from my Solo controller
My first and biggest question is can I operate an X8 octocopter on Solex with the Green Cube instead of the quad Solo?
I figured that to run Solex and operate this as a Solo from my Solo controller…only it’s an octo instead of a quad…that I would need the Green Cube that is specific to Solo?
Or I guess I could accomplish using my Solo controller with Solex and use the Black Cube?
3dr fixed the esc issue using slew rate in software. The grean cube was a hardware fix for the same issue. That allowed us to use updated arducopter firmware that at the time didn’t have slew rate. @philip Can you help me explain this I’m apparently not doing a good job of it
