Hey guys, would it be possible to put in the ability to flip the image on the video coming in through the HDMI port, it it’s not possible already? I’m using a GoPro Hero 7 for a FPV camera and for whatever reason, GoPro has decided not to give users the ability to output an image through HDMI that is upside down. On the 5 and 6 it’s not a problem, but for whatever reason the 7 doesn’t have this function. I figured it would be easier to request a firmware change through you all than GoPro
It works when I use the camera regularly… but when I plug in the HDMI no matter what I do it will not flip the image. You’re not having the same problem?
Thanks for adding it, it would be a good feature to have!
Correct… but that is only for viewing it on the back of the camera. As soon as you plug in the HDMI and view the image on the device (in this case, HereLink), no matter what setting I choose the image is always right side up. So if I mount my camera upside down the image is upside down.
After looking through the forums it appears to be only a problem with the Hero 7. The 6, 5, and 4 don’t do this…
